Were you aware of how to download images from Cricut Design Space? It is true, as Cricut software is the most crucial feature crafters need to use while using the Cricut machine. Also, it can use the downloaded images and convert them into cuttable images. Most beginners ask about downloading and uploading images to the Cricut app. Simply put, it is a straightforward process that allows you to get the image on your device within a few seconds.
In addition, you can download the image from a web browser for free or through a Cricut Access subscription plan. Are you ready to learn the facts about taking pictures while preparing your favorite project? If yes, then this blog is perfect for you, as it will explain the entire method in simple words.
Step 1: Search and Download An Image
If you intend to learn about how to download images from Cricut Design Space, open the search engine (Google Chrome, Safari, MS Bing, and others) and look for your image. After the list opens, right-click and click the Save as Image or Save Images to Downloads option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space.jpg?w=415)
After successfully downloading the image, go to the Downloads folder and check whether it has been downloaded perfectly. If it isn't appropriately downloaded, try re-downloading it from another search engine. Also, you can try downloading different images and checking the internet connectivity.
Step 2: Upload Your Image to the Cricut App
Following this, turn on your device and open the Cricut software, which is visible with the other installed app on the Home screen. To learn how to download images from Cricut Design Space, create an account or sign in by noting down your Cricut ID and password.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space2.png?w=327)
Next, you will land on the new web page and press the New Project present at the top-right-hand side or in the center of the page. Now, click the Upload tool given under the Menu bar on the left side of your canvas.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space5.jpg?w=817)
Following this, click Upload image > Browse, and your device's Downloads folder will instantly open. Now, select your downloaded image and then click the Open button. After that, click the Complex > Continue option. At this point, you will instantly be connected to the background remover page.
Step 3: Remove Background
Subsequently, use the background remover tool by selecting the background of your downloaded image. Then, click on the places where you want to make the changes and click the Apply & Continue button at the bottom right side of the page. Plus, choose the Cut Image and remove the background of your downloaded image. Following this, tap the Upload button present at the bottom right side of your page.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space3-1.jpg?w=1024)
Step 4: Upload SVG File to Cricut Design Space
Afterward, you will see the edited image under the Recently Uploads > choose the image and then click the Add to Canvas button. Equally important, resize your image and then select the Make It option. Further, select the image on the cutting mat and proceed towards the cutting process.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space4-1.jpg?w=586)
It doesn't matter whether you are using a Basic image or a Vector image; you need to follow some steps. If you aren't aware of the methods, refer to the section below.
Method 1: Upload Basic Images (Raster Images)
Further on how to download images from Cricut Design Space, choose the Basic images in .jpg, .gif, and .png and drag them to the Cricut software's Upload window. Now, choose the image type and then click the Continue option. Next, choose the Crop tool to remove, erase, and restore the unwanted background.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space6-1.png?w=1024)
If you want to preview the edited image, press the Preview button on your screen. If you don't get the desired image, press the Hide Preview button and edit it. After making the modifications, select Continue to proceed to the next stage. Concurrently, name your image and choose Print Then Cut or a Cut Image. Equally important, click Upload, and your edited image will appear in the Uploaded Images Library section.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space7-1.png?w=1024)
Method 2: Upload Vector Image
On the contrary, if you are using a .svg or .dxf file, go to the File Selector and select the Open option. Then, drop the file in the image upload window, name it, tag it, and hit the Upload box. Also, return to the Upload section and search for your Vector file by inserting its name inside the Search bar.
At this point, choose the file, and it will directly move to your Cricut app canvas. Finally, the Vector images that are designed with layers will appear as grouped images. After ungrouping the image, you can move and change its size separately per your preference.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-to-download-images-from-cricut-design-space8.png?w=1024)
If you would love to explore how to download images from Cricut Design Space more, keep going by using the cutting machine and the designing software. Moreover, try to access the majority of content related to the app that will motivate you to unleash your creativity.
Frequently Asked Questions
Question: Where Can I Find My Uploaded Images in Cricut Software?
Answer: Take a look at the below steps, and you will find the images that you uploaded on the Cricut app:
- Start the process by opening your Cricut Design app.
- Next, click the Images option given under the Menu panel.
- From the list, you will find all the downloaded or uploaded images by name.
- Also, you get the option to find the image in the Upload section.
Question: How Do I Load My Images Into Cricut Design Space on My iOS Device?
Answer: Refer to the following steps and load your favorite images on your Cricut Design app installed on your iOS device:
- First, open your Cricut app and tick the Upload option.
- Next, click the Browse File and choose the folder where you want to upload the image.
- Now, choose the Basic or Vector image and make the necessary changes.
- Finally, click the Upload option at the top of the page.
Question: Can I Use My Cricut Software Without the Internet?
Answer: You can surely use the downloaded images to make several customized projects without having an internet connection. Also, you get the right to edit the images and complete the leftover project using the tools given under the Menu panel. But you can't use the Cricut Access app without having an internet connection.
