It’s been over a year since I started operating Cricut cutting machines to create DIY projects. Initially, I was completely unaware of Cricut models, its software, and how to use them. But my fighting spirit uplifted me to keep going, and I started researching them. It was time-consuming, but I learned about installing the Cricut software, creating a Cricut ID, and the Cricut Design Space login app process.
Cricut Design Space is the company’s registered design software, providing crafters with a wide range of benefits. With this Cricut app, you must get it on your device to make uncountable crafts. Afterward, you should create a Cricut ID and access your account through login credentials. Keep going with the blog, as I covered the continuous info regarding installation, creating an ID, and logging into the account.
Step 1: Download Cricut Design Space on Your Mobile Device
The foremost step before proceeding with the Cricut Design Space login app is to install Cricut software on your mobile devices. You can use this software as an app rather than opening it in a web browser. Exam the section below to install the app on Android or iOS devices.
Android
With the help of the following method, it will become simple for you to install this software on your Android devices:
- Commence the process by switching on your devices and start looking for the Google Play Store.
- You will find the app with other installed apps on the home screen.
- Now, click the Play Store to open the app on your device.
- Next, look for the Cricut Design app or type its name inside the Search box.
- After getting lucky in finding the app, tap the Install button given inside the blue box.
- At this point, you will notice that the app will appear next to other installed apps.
After installing this Cricut Design app on an Android device, quickly scan the next section. It will introduce you to the method for installing on various iOS devices.
iOS
Equally important, take the help of the following steps to install this software on your iOS devices:
- First, unlock your iOS device and open the App Store.
- Second, search for Cricut Design Space and then tap the Get option.
- Third, double-click the power button to install the Cricut software.
- Moreover, you can also enter your iTunes password to verify the app installation.
- Now, sit back until the app is installed on your iOS device.
- After the app gets installed, close the App Store tab.
- Now open the app and choose Machine Setup or Sign In.
- Conclude the installation process by creating new projects using this software.
Further adding to the blog, you must have your separate Cricut account; only then will you get permission to use the Cricut app for crafting purposes.
Step 2: Create a Cricut Account ID on Your Device
Before entering the Cricut Design Space login app, you must create a separate Cricut ID. If you fail, you won’t be able to access the software and create DIY crafts. By considering the below steps, it will become a piece of cake for you to make your separate account:
- You can install the Cricut Design app on your mobile device by following the above-said method.
- Afterward, open the installed app, and the Cricut sign-in page will open on your device.
- Now, tap the Cricut a Cricut ID, and you will be on the new web page.
- On this page, start filling in the blank with your First name, last name, personal Email ID, and password.
- Following this, tap the checkboxes and hit the Create Cricut ID option.
- Finally, you are eligible to access the Cricut Design Space login app and use it to create new projects.
After successfully creating your Cricut ID, you can easily log in to your Cricut account without any technical errors. If you intend to do that, take a sneak peek at the coming section of the blog.
Step 3: Cricut Design Space Login App
In conclusion with this blog, get to know about how you can log in to the Cricut app with the help of the following steps:
- With the help of the formerly-said method, you must have installed and created your Cricut ID.
- After that, open the Design Space app and tap the Sign In box.
- At this point, enter your Cricut ID and password, which you will receive after creating an account.
- Now, tick the Sign In option in the middle of the page.
- Further, you will get connected to the Cricut Design Space app.
- Lastly, you can start drawing your DIY design ideas on the canvas.
Conclusion
In conclusion, the Cricut software is the most crucial tool for crafting. Without it, you won’t be able to form the inner DIY ideas correctly. To get this Cricut app on your device, you must check whether your device meets the system requirements. Afterward, you can easily install the app on your smartphone. You also need to log in to your account and then log in again to use it to create various designs.
Visit: install cricut design space app www.cricut.com/setup login
