My grandchildren gifted me a Cricut machine on my 50th birthday a few days ago, and I was overjoyed. My favorite of the Cricut series is the latest version of the Explore series, the Cricut Explore Air 2. This versatile machine is designed with simplicity and value in mind. I need to execute the Cricut Explore Air 2 machine set up on my Windows and Mac computers to create unique designs on fabric.
Once I am done setting up this Cricut Explore model on a desktop, connecting devices via wireless and wired methods will be easy. Putting everything aside, I must download the Cricut software onto my separate computer. I will also be able to make DIY projects on a regular basis. This post covers everything from setting up Cricut Explore Air 2 to connecting it to a computer.
Cricut Explore Air 2 Machine Set up on Desktop Using a USB Cable
If you want to draw your ideal do-it-yourself craft out of Explore Air 2, you must set up this Cricut machine on my Windows/Mac systems. To perform this method laudably, keep an eagle eye given to you underneath:
- Lay the first stone of the setup process by unpacking this model and other supplies.
- After that, plug it into the supportable wall pocket and turn it on.
- Now, connect it to your desktop via a USB cable or pair it wirelessly.
- Following this, open your device's web browser and go to design.cricut.com/setup.
- Next, download the Cricut software, sign in, or create your Cricut ID.
- Afterward, go through the instructions shared on your system screen.
- Then, start setting up the device by following the instructions.
- Finally, your Cricut Explore Air 2 machine set up will end when you are called to do a test cut on the material.
With the finalization to set up Cricut Explore Air 2 on desktop, go forward by getting to know about connecting the Explore Air 2 machine to Windows and Mac computers.
Connect Cricut Explore Air 2 to Desktop via Bluetooth
As said in the above paragraphs of this tutorial, there are two ways to connect this Cricut machine to your desktop. One of the easiest and most popular methods is connecting them wirelessly (Bluetooth). Below are the tips that will make your process straightforward:
For Windows
Once you are done with the Cricut Explore Air 2 machine set up, let's discuss the process using which you wirelessly execute the process:
- Get going with the process by switching on your machine and within 10-15 ft of your Windows.
- Now, open the Start menu >select Settings (Gear icon) and then choose the Devices option.
- After that, cross-check that your Windows system's Bluetooth is on.
- If it isn't, move its toggle to the right side, and it will instantly be activated.
- Next, choose Add Bluetooth or other devices at the top of the Bluetooth option.
- Further, tick the Bluetooth given inside the Add a Device section.
- Then, a new pop-up window will open on your device screen.
- At this point, look for your machine model and click it.
- By referring to these steps, both of your devices will be connected to each other.
- Close the Settings tab, open the Cricut app, and go to the New Product Setup page.
- Conclude the process by checking that the wireless connection process among your devices has been done correctly or not.
With the assistance of these steps, it will become child's play for you to connect the Explore Air 2 machine to a Windows PC wirelessly.
For Mac
After concluding the Cricut Explore Air 2 machine set up on Mac, let's take a step forward by examining the steps for connecting your computer to this machine.
- Redo step 1, which you performed while wirelessly connecting this craft plotter to Windows.
- Further, tick the Apple icon given on the left side of your home page.
- Then, select the System Preference and click the Bluetooth icon.
- Now, check that your Mac system's Bluetooth is on, and click the Turn Bluetooth On option.
- Following this, tap the Cricut Explore model given inside the Devices section.
- After a few minutes, you will get a message about the successful connection process.
- Summing up the process, proceed back towards the Cricut Design Space and start creating your design on the app.
Studying this blog on setting up Cricut Explore Air 2 to Windows will become a piece of cake for you to create personalized crafts. Some of the prominent crafts include greeting cards, banners, home decor items, paper wreaths, doormats, wood signs, and so much more.
Frequently Asked Questions
Question: How Do I Set up My Cricut Explore Air 2 on Mobile Devices?
Answer: Follow the below steps and set up your Explore Air 2 machine on mobile devices:
- Start the method by plugging this Cricut model in and switching it on.
- After turning on the power button, pair your device via Bluetooth.
- Then, download & install Cricut Design Space on your smartphone.
- Following this, create your account > sign in & follow the instructions.
- You will be able to set up both devices by following the instructions.
- Finally, a material-cutting test will be done when the setup is concluded.
Question: Do I Need a Cricut App to Work With My Cricut Explore Air 2?
Answer: To draw your best designs from this Cricut machine, you need to have the Cricut software on your PCs and smartphones. Without this app, you won't be able to give perfect formation to your imaginary designs into the perfect shape or size. Also, this app allows you to transfer the designs to the Cricut machine and cut the material as per the command.
Question: How Can I Use My Cricut Explore Air 2?
Answer: To use the latest model of the Cricut Explore series, you need to download the Cricut Design app, set up, connect & pair the machine to your devices. After completing all these processes, you will be able to use it for creating various crafts such as:
- Leather earrings
- Table runner
- DIY Wine glasses
- Graduation cards
- Coasters
- Birthday cards
- Garlands
