Hey, are you looking for a guide that teaches you about Cricut Explore Air 2 connect Bluetooth? If yes, then you are in the right place. Through this blog, I will teach you how to connect a Cricut cutting machine to a computer and mobile device using Bluetooth. In this guide, I have explained the steps for Windows, macOS, iOS, and Android.
As a beginner, I understand the initial challenges of starting a crafting journey with Cricut. But with discipline, I was able to create something new every day. In fact, I was so inspired by my progress that I decided to pursue crafting full-time. The experience was really beneficial, as I learned not only to set up and connect the machine but also to create intricate designs.
Let’s delve into this blog and learn how to connect Cricut Explore Air 2 Bluetooth to Windows, Mac, Android, and iOS. Let’s get into it!
Cricut Explore Air 2 Connect Bluetooth on Windows
When it comes to connecting a Cricut machine to a Windows computer, I find it superbly easy. It was the first computer that I used when I started my first crafting journey, using an older version of Cricut. To connect your Cricut to your Windows PC, follow the steps that I have written below:
- In the beginning, find a flat surface.
- Place your Cricut Explore Air 2 on it.
- Maintain a gap of about 10 - 15 feet between your computer and Windows PC.
- Next, you need to head to your taskbar.
- After that, you will have to click on the Start menu.
- Now, you have to open Settings. To do this, click on a gear icon.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-explore-air-2-connect-bluetooth.png?w=491)
- As you are on the Settings page, you need to move on to the Devices option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-explore-air-2-connect-bluetooth0-1.png?w=889)
- Afterward, you have to turn on your Bluetooth.
- Then, simply select Add Bluetooth or other device.
- Post this, select the Bluetooth option.
- Wait until your PC detects your Cricut Explore machine.
- Once detected, click on it to pair.
Cricut Explore Air 2 Connect Bluetooth on Mac
Mac was the second and last computer I have used. After Windows, it was my best decision to go with Mac. I switched to a Mac because I wanted a more secure device, and as a professional crafter and a business owner, it was essential for me to use a Mac for my Cricut.
- Look for a flat surface such as your table.
- Place your Cricut Explore machine on it.
- Once you have placed your Cricut in its right place, maintain a distance between a computer and the Cricut.
- To maintain a gap or distance, ensure your Mac is within the range of 10 to 15 feet.
- After that, navigate to the Apple menu > System Preferences.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-explore-air-2-connect-bluetooth1-2.jpg?w=321)
- Then, check for the Bluetooth option on your Mac.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-explore-air-2-connect-bluetooth4-1.jpg?w=631)
- In the next step, turn on the Bluetooth.
- Wait and see if your Cricut is detected.
- Once it is visible, select it to connect.
Cricut Explore Air 2 Connect Bluetooth on Android
When I first tried to use an Android device, I was really excited. It was a great feeling I had ever had when using my Cricut on an Android device. Be it Motorola or Samsung Galaxy, Cricut supports a wide range of Android devices. Let’s start!
- Setup your Cricut by placing it in the right place, such as a flat surface or table.
- After that, you need to power it on.
- Once it is powered on, ensure that the gap is not more than 15 feet between your Cricut and your phone.
- On the following screen, head to Settings.
- Now, to access Bluetooth, reach the Bluetooth option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-explore-air-2-connect-bluetooth2.jpg?w=322)
- Then, turn on your Bluetooth.
- Once Bluetooth is on, you will need to select the name of the Bluetooth module.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-explore-air-2-connect-bluetooth5-1.png?w=512)
- When it asks you to enter the four digits of your PIN, then enter 0000.
- After that, your Cricut cutting machine will be connected to an Android device via Bluetooth.
Cricut Explore Air 2 Connect Bluetooth on iOS
Being an iOS user, using Cricut with this device is not only handy but also safer than using an Android device. iOS users can get security as well as a handy feature to connect your Cricut to an iPhone or iPad.
- Place your Cricut properly within a range of 10 to 15 feet.
- Also, be near your Cricut so that it can be connected easily via Bluetooth.
- After that, you will need to go to Settings on your iPhone.
- Once you are on the Settings page, turn on the Bluetooth.
- When you have found your Cricut, you have to select it to pair.
- In the case of PIN, just enter 0000.
- Lastly, tap the Pair button, and then you are done.
FAQs
Question 1: How can I connect my Cricut Explore Air 2 to my device?
Answer: In order to connect a Cricut to your device, you can use either USB or Bluetooth. To connect via Bluetooth, you need to follow the different steps for different devices. The steps are different for Windows, Mac, Android, and iOS. However, to connect your Cricut to every device, you first have to place the machine near your device and then enable Bluetooth on your device. After that, you need to find your Cricut on your device and then click on it to pair.
Question 2: How to plug in my Cricut Explore Air 2?
Answer: The back of your Cricut Explore machine has two spots where you can easily plug your power cords in. Simply put, you need to insert the power cord into the right, as on the left side, there is a port for a USB cord, which you can use to insert one end of the USB cable to connect your devices.
Question 3: How to put my Cricut in pairing mode?
Answer: In order to put your Cricut in pairing mode, you have to place your Cricut near your device within the range of 10 to 15 feet of your device. Then, you have to go to settings and then enable Bluetooth. After that, you have to wait and look for your Cricut device to appear on available devices. Once detected, select it, and your Cricut will be in pairing mode.
