Acne is something that can be hard to deal with. It can be embarrassing and make you feel ugly and less than. If you are struggling with acne, here are some tips that can help your skin and make you feel a little better about your situation. You will find that some will work better for you than others.
Try using lemons to combat acne breakouts. Some people find that lemon juice is very effective in getting rid of acne. If you have enlarged pores and oily skin, try applying lemon juice to the area. You should limit the use of lemon juice to only once or twice a week to avoid drying out your skin.
Birth control can both be a cause and a preventative treatment for acne. For many adult women, going on the pill is to treat their adult acne. The pills contain hormones that can help the female's own hormones find balance and some get clearer skin out of this. Many times though, when they get off of the pill, this can cause they're hormones to go haywire and they can start breaking out again.
Acne scars can be eliminated via a surgery, such as laser surgery. This is something that has to be suggested by your dermatologist though. Basically, they use a gentle laser and go over the scars. Through repeated treatments, you will start to see these scars diminish and go away for long periods of time.
One of the best ways to deal with acne is to see a dermatologist. The dermatologist can specifically tell you ways to deal with acne that is affecting your skin without causing any further problems down the road. The dermatologist may also be able to prescribe special topical medications or antibiotics that can eliminate acne.
You always want to take extreme caution when deciding on prescription medication for your acne. A lot of the pills out there, have really negative side effects, so you will want to weigh the pros and cons. Sometimes acne is better off being treated naturally, rather than dealing with the side effects from drugs.
To get rid of acne, it is important to eat as many vegetables, fruits and nuts as you can. Acne has been known to form because the body has deficiencies in certain minerals that these foods contain. Try making yourself smoothies with the fruit, snacking on the nuts and eating at least one salad a day.
One of the best treatments that you can try is micro-needling for your acne scars. This process uses a roller with hundreds of small needles that puncture your skin. Over time, your collagen will grow back, filling in your acne. This treatment is great for deep, cystic acne scarring.
If you have tried every over-the-counter treatment for your acne to no avail, seeking professional help may be in order. A doctor or dermatologist can not only help you to discover what might be causing your problem but they can prescribe stronger antibiotics and other remedies that will give you the results you need. Having acne is not unusual nor does it mean there is anything wrong with you; ask for help if you need it.
Cutting sugar and increasing your fruit and vegetable intake in your diet will help reduce the number of acne breakouts you suffer from. Also add some fatty fish, like salmon, to your diet. These simple additions to your diet and cutting the sugar out are going to lead to clearer skin.
Use oil-free moisturizers to keep skin well-hydrated so that you are not exacerbating acne in oily skin. Try to find a water-based moisturizer and be sure to check the ingredients for anything that could potentially lead to acne breakouts. Some of the ingredients that may need to be avoided are oily substances, such as, coconut oils or mineral oils.
Honey and yogurt can make a great acne mask. Just mix one part honey to two parts yogurt. Apply to the entire face and leave on for about fifteen minutes. The yogurt has soothing properties and the honey has antiseptic properties. They are both wonderful for clearing your skin and keeping it fresh.
Heat and light therapy can sometimes be used effectively to treat acne. This treatment involves applying intense heat to the skin, while also using a strong light source. The process clears the skin of bacteria and cuts down the size of some glands as well. The method should only be performed by a licensed Dermatologist.
If you want to get rid of your acne quickly, try combining aspirin with lemon juice. Crush the aspirin and mix it with a little lemon juice. Put the liquid on your blemishes and leave it on overnight. Aspirin has a certain type of acid in it that helps your skin heal. Lemon juice has similar healing qualities.
Cotton can be one of a acne-sufferer's best friends. Clothing made of synthetic materials, such as nylon, can keep the skin from breathing. Wear cotton as much as possible, to keep skin dry and comfortable. Cotton bedsheets can also keep your skin healthier and keep sweating to a minimum.
Keep your face clean every day, even if you do not have a breakout. Also, use soap that is specifically made to wash your face. Washing your face removes dead skin cells, dirt and oil from your skin to help prevent new breakouts. Using a deodorant soap or any other soap meant for your body, can irritate your facial skin, or inflame a current breakout.
For controlling acne, don't use face washes or cleansers with oil or perfumes in them. Oil in these products can clog pores and cause new pimples to appear. Perfumes are not advised because they can burn or irritate the already sensitive, delicate skin associated with acne.
By now you can see there are a lot of ways to help with acne. Experiment with what works best for you and your skin type. Acne usually gets better, so don't worry too much about it right now. There is something out three that will help you become acne free.
