This is weird: USB keyboard works with connector, but not directly wired.
Starhawk wrote 04/20/2019 at 22:16 • 0 pointI have a known good MagicForce 68-key keyboard. It comes with a cable and a USB Mini-B connector (NOT MicroUSB!).
If I use it with its original cable and connector, it works. I tried it once with another USB Mini-B cable and it did not work, but I believe that was a bad cable. I have since removed the connector and direct-soldered another USB cable to it and it doesn't want to work now -- but the cable I'm using it with is tested and known good.
What am I missing...?
Turns out the missing shield was the issue. I found another pretty cable (I wanted a pretty one, that was the point) and it was shielded, so I used it instead. Keyboard works now.
I doubt if it's interference that the shield is preventing but rather that they have used the shield as one of the lines.
Maybe there's a chip inside the connector?
I have been tinkering with V-USB with an ATTiny841 (using the Micronucleus bootloader) on a breadboard and encountered similar issues - when connected to my laptop with the USB2.0 hub on my desk it works fine, but using different, USB3.0 hubs or directly into a USB3.0 port, it just isn't recognised. I haven't had time to dive into it, but my guess is that some software USB implementations are not fully USB3 compliant. Using some hubs/cables (most likely USB2 hubs/cables) helps avoid these issues.
So it could be that the microcontroller in your keyboard is using V-USB and therefore isn't USB3.0 compatible. The cable that works might be a USB2 cable, that fixes (or hides) the incompatibility.
As far as I know USB3 connector has actually 2 interfaces - USB2.0 with power D+/D- for backward compatibility and a separate USB3 RX & TX diff pairs and a ground. These two shows up as two separate ports under USBtreeview. USB3 hub similarly have two functional hubs in one.
http://billauer.co.il/blog/wp-content/uploads/2015/12/cypress-hub-controller.jpg
My ATMega VUSB uses a crystal works fine with USB3 port as well as a USB3 hub. May be the ATTiny VUSB with its RC timing is a bit outside of the tolerance of newer USB implementation? It was quite a bit of a hack as is.
BTW my $3 keyboard from a "Dollar store" works fine on a 3.0 port.
It might be a timing issue, but V-USB is known to have incompatibilities with USB 3.0, even when using a crystal, especially on Windows computers it seems. Most posts I have found online about V-USB and USB 3.0 say to use a USB 2.0 hub as it just doesn't work reliably otherwise. I hope to get some time over the coming week to dig into this deeper and find out what is happening...
It uses some non-standard pinout in both the PCB connector and the cable that cancel each other out?
Or, you didn't solder the cable right :-)
Just guesses, of course.
Actually, after looking in dmesg on Linux... it doesn't appear to be fully USB compliant. The cable I'm using is an unshielded cable - meaning that the microcontroller should downshift from USB2 to USB 1.x, and it appears that it's not doing that downshift.
Most cheap Chinese cables I have seen do not have shields. I have also made my own USB2 extension cables out of retwisting stranded cat5 patch cord pairs. They seem to work okay connecting a USB2 hub to PC host at high speed.
In fact, if I've got the right datasheet, the microcontroller being used is abusing its I2C lines to run the USB data. The writing is very small on a very small chip, though, so I could be wrong. It could also easily be a counterfeit chip with the wrong label, or a custom OEM variant that's undocumented.
https://www.cypress.com/file/134171/download
>A 1.5-kΩ pull-up on the D+ line indicates that the attached device is a Full-Speed device. A 1.5-kΩ pull-up resistor on the D- line indicates the attached device is a Low-Speed device.
>High-Speed devices start as Full-Speed devices, so they have a 1.5-kΩ pull-up on the D+ line. When the device is connected, it emits a sequence of J-States and K-States during the reset phase of enumeration. If the hub supports High-Speed, then the pull-up resistor is removed.
USB keyboards reverts to PS/2 if they detect pull ups (instead of 15K pull downs from USB host) on both lines. PS/2 is also bit-bang.
Generic lower end keyboards and similarly software bit-bang USB tends to be Low Speed device. They cannot be enumerated to Full Speed or High Speed by mistake.
Does the funny cable have a 1.5K (or higher) pull up hidden inside?
(Coincidentally, I also use I2C port on my ChibiTerm as PS/2 interface for keyboards because it was full 5V tolerant. I can't use it for anything else because it only has open drain.)
