UratechUSA is a decade old concern, knowing the market standards and industrial needs. A clear understanding and the well-versed experience in the machining field guides us to create the feasible CNC storage cabinets with fine quality. Uratech always excels in their product design and quality, which helps the customer to safeguard their work place and investments. Our tool cart offers the best support to the machine tools which tends the business to increase their productivity.
A clear market study helps us to design the fine quality product which fits most of the industrial requirement. To withstand a longer run, the raw material used for manufacturing our tool carts are particularly hand-picked with extra care.CNC Tool trolley is our major product which is highly demandable one in the market. According to your industrial area and specifications, you can pick the best from our variety of tool storage trolleys we manufacture. Here in this blog, you can able to learn more about the types of CNC tool cart that we manufacture and the raw materials used to build it.
Types of CNC Tool Cart We Manufacture:
The need of CNC tool storage cabinets will differ according to the industries. To offer the vital requirements of the customer, UratechUSA manufactures 6 types of industry specific CNC Tool carts, which suit the best for all type of industries.
- Floor Model (All types of CNC Holders)
- Steps Model (All types of CNC Holders)
- Ladder Model (All types of CNC Holders)
- Shelf Model (All types of CNC Holders)
- Secured Model (All types of CNC Holders)
- Bench Model (All types of CNC Holders)
Cold Rolled Steel:
Cold rolled steel is a type of raw material used in our unique CNC trolley manufacturing. In this process the steel metal is used to roll in the room temperature which helps the sheet to have perfect finishing and gives a good look to the CNC cart. Therefore, there will be no extra patching works needed to make it look properly. For our specific CNC tool cart, we use (16 gauge Thickness, 1.6mm (0.063”)) to gain High Strength & Durability.
Nylon Inserts:
Due to its thermoplastic feature and its ability to withstand heat, nylons were used as the raw material for inserts. It also gives us the great advantage of having greater rigidity and strength. Nylon was the first commercially successful synthetic thermoplastic polymer. These inserts were used in the industrial area to safeguard the tools, particularly the workplace which emits greater amount of heat.
Uratech offers 2 variants of inserts, one is lockable and the other is unlockable.
Lockable inserts firmly hold the Tool storage trolleys in one position which prevents the Holders from Shaking while moving through rough surfaces. The lockable tool storage trolleys has its unique features which makes it the fastest moving model in the industry. UnLockable inserts can also hold the machine tools, and these types of inserts are used for specific purposes. So, according to your requirements, you can choose the best which suits your ideal needs.
Powder Coating:
Powder coating is a procedure in which the paint is sprayed over the material to give a perfect finish to the product. Since cold rolled steel is the raw material, this particular method gives a unique and mirror finishing to the cart. Its unique feature offers the CNC tool cart products to resist from corrosion and it offers rust free industrial environment.
Nuts with Nylon:
The perfect assembly structured tool should withhold the capacity of the tool within the body strength of a tool cart. When the parts of the CNC storage cabinets are fixed and screwed perfectly, it can bear a huge load. So, a p perfect screwing and fixing should be done to avoid accidental damages. For the finest body structure and fitness of the Cart, we use Nylon inserted nuts. Nuts with the nylon piece at the end of it help to avoid the loosening of the tool when used in the rough industrial floor. It seems the nuts and bolts were very small figure, but when compared to the lifetime of the tool, they play a major part of it.
Aluminium handle:
Due to its lightweight, corrosion resistance, non-magnetic and many other features, aluminium is used as the raw material in most of the industrial products. At Uratech, we make use of aluminium as the raw material to make the finest tool handles which withstands for a long.
Peg Boards:
Pegboards are used in some of the CNC tool carts, as they help in hanging the tools in the stand for easy access. For slightly bigger or varied tools the hooks also differ as it needs to withstand the weight. These peg boards save a lot of time as it helps the workers to have a simple access to their tool needs whenever they require. It can also avoid lots of mess in the work area.
Castors:
Castors are the most important material for the movement of the cart on the working floor. There are 2 types of materials which were used in manufacturing our CNC tool trolley. One is rigid which allows only forward and backward movements and another one with swivels which are responsible for multiple directions. These swivels castors have the feature of breaks which allows us to control the cart quite easily. Polyurethane Caster Wheels with Ball Bearings resist most chemicals, cushion loads, and help in protecting floors. Ball bearings allow wheels to run directly on the axle or spanner bushing. Polyurethane cores help cushion loads and offer superior chemical and water resistance. These castors are made up of polyurethane to ensure smooth rolling in the industrial area. They can able to withhold a load capacity of up to 11000lbs. Visit our website or call us anytime to know more details about the variant of CNC tool carts that UratechUSA manufactures. If there is customization to be done in the products according to your industrial needs, we deliver the best which suits your ideal requirements.
