PHP is the most commonly used scripting language worldwide, to build web solutions. It puts its users at complete ease with its framework that cuts down on development cost and time. With such readily available PHP framework, you can avoid writing repetitive code while building exceedingly fast applications (RAD).
Talking about Laravel, it is an open-source PHP framework that is well-known to develop MVC based applications. It is completely compatible with web hosting accounts. In September, it released its latest version Laravel 6 that focused on various improvements and additions to serve its users finer.
In this post, I will be listing down those enhancements and other features that you can explore with Laravel 6 in regards to your website development. Let’s start!
Follow Semantic Versioning
The process of semantic versioning or semver can be defined as a set of defined rules that tells about the various alterations that increase the version numbers. Every package comes with v.v.v form where each part discusses different values ranging from major, minor, and patch.
Where Major refers to the breaking features increment and any new non-breaking features increment represents the minor version number. At last, patch refers to the bug fixes to the existing features increment.
Ignition Shipping
Laravel 6 explores a new open-source exception page, i.e., ignition. To define, Ignition is the default error page for Laravel, and it holds few exquisite features that are specifically made for Laravel only and allows better-debugging exceptions and tracing stacks.
All in all, you would get an enhanced user interface that lets you share errors, handling line numbers, and track exceptions along with solutions for some common sort of issues. To enjoy this custom and framework-oriented feature, you can take development help from a PHP company that can provide you with better glances into it.
Custom error messages
With Laravel 6, you can provide custom error messages around authorization to end-users, unlike the previous versions of Laravel. With the introduction of Gate::inspect(‘X’, ‘Y’) method, you can fetch the authorization policy’s responses.
Additively, the authorization response messages will be returned to the frontend automatically whilst utilizing Gate::authorize, $this->authorize from controllers or routes. You can simply instruct this method with if condition containing access or restrictions.
Adoption of Lazy Collections
Lazy collections refer to the process of keeping memory usage low whenever working with huge data sets. While working with extensive data collections such as Eloquent model, lazy collections work well. This class is represented as Illuminate\Support\LazyCollection.
You can restate whole data collection with LazyCollection::make() besides with ‘yield’ PHP function, that too without loading. For a detailed overview of this feature, you can have a look at its official release.
Separate Laravel UI Composer Package
With Laravel 6, you would get the front-end scaffolding into an abstracted laravel/ui composer package that stays separated from the primary Laravel framework. That means you would get Vue or Bootstrap code in the default framework structure. On the contrary, make::auth command has been pulled out.
Well, this is all with the latest release of Laravel, i.e., Laravel 6. Overall, all the enhancements and additions saw beneficial for the developers while aiming to develop user-friendly interfaces. However, it is always advisable to look into the official documents of the software, for an appropriate and more relevant information on the updates and releases.
And, if you come across any sort of difficulty in understanding the significance of this latest release, do not hesitate from consulting an expert.
