This article shows how you can make a 555 timer sound generator. This generator produces square wave and allows amplitude control.
Step 1: Design the Circuit
I drawn the circuit with PSpice software:
The three Q4 transistors are acting as an equivalent resistor thus reducing the amplitude of output signal. A higher Q4 transistor base current reduces the output voltage and thus AC signal magnitude.
Calculate minimum equivalent resistance at input of Q1 transistor:
Req = Vb1/Ib1
Ib1 = Ie1 / (Beta + 1)
= Ie2 / (Beta + 1) / (Beta + 1)
= Ie3 / (Beta + 1) / (Beta + 1) / (Beta + 1)
Ie3 = (Vs - Vbe*4) / Rb4
= 0.01589743589 A
Ib1 = 0.0000017166 A
Req = 5.2429 Megohms
Calculate high pass filter frequency:
fh = 1/(2*pi*(Rs1+Rs2+Rspeaker)*Cs2)
= 1/(2*pi*(22*2 ohms + 4 ohms)*(220*10^-6))
= 15.0714908231 Hz
Calculate the time constants of charging C1 or C2 capacitor:
Tmin = 1/(Rc1a*C1) = 0.22 seconds
Tmax = 1/((Rc1a+Rc1b)*C1) = 22.22 seconds
Calculate the 555 Timer minimum and maximum frequency:
fmin = 1/(1.386*(Rd2 + Rf)*Cd) = 35.8955582836 Hz
fmax = 1/(1.386*Rd*Cd) = 7215.00721501 Hz or 7.215 kHz
(555 Timer Information: https://www.electronics-tutorials.ws/waveforms/555_oscillator.html)
Step 2: Simulations
Simulations show a reasonable high amplitude oscillation because I assumed a speaker impedance of 100 ohms. in real life the speaker impedance could be as low as 4 ohms and thus reducing the output amplitude.
