Smart WiFi Touch Switch ewelink app PINC Technology
pinc-technologyPinc Technology wrote 04/29/2020 at 05:42 • 2 min read • Like
Pinc technology manufactured the WiFi touch switch for smart home automation. In this video. we are going to show you how to install the eWelink app for your android or iOS play store and configure our modular wifi touch smart switch.
Download and install eWelink from google or iOS AppStore.
Register yourself by giving email id and mobile number if you use the first time this app. Make sure that you are in provision mode.
How to check the device is provision mode?
The BLUE LED will blink 3 times per second then the device is in provision mode.
This switch is the combination of the wi-fi and touch. Now you can order this switch from Amazon, Flipkart, Snapdeal, Club factory, etc.
This switch supports Amazon Alexa, IFTTT, google home. This switch operates from 85 volt AC to 265 volt AC with 50 or 60 Hz frequency.
It supports 10 amp of current. The wi-fi is IEEE compliance with b, g,n mode with 2.4 Ghertz frequency. The size of the switch is very small 50X45X24 mm. The wiring of this switch is very easy.
There are only 4 wires. 2 wires are input and 2 wires for the output.
The switch is compatible with the anchor Roma standard which is specially designed for the Indian standard. You can turn this on and off by mobile phone as well as touch.
You can mail us on business@pinctechnology.com
For bulk inquiry please contact us on WhatsApp business or call us on 6351519021 or 9925020032.
Like
