This book will help you to gain more knowledge about Arduino
Beginning Arduino
![Piezo Knock Sensor](https://www.mechatronicslab.net/my_uploads/2020/06/Piezo-Knock-Sensor-300x206.jpg)
int ledPin = 9; // LED on Digital Pin 9 int piezoPin = 5; // Piezo on Analog Pin 5 int threshold = 120; // The sensor value to reach before activation int sensorValue = 0; // A variable to store the value read from the sensor float ledValue = 0; // The brightness of the LED void setup() { pinMode(ledPin, OUTPUT); // Set the ledPin to an OUTPUT // Flash the LED twice to show the program has started digitalWrite(ledPin, HIGH); delay(150); digitalWrite(ledPin, LOW); delay(150); digitalWrite(ledPin, HIGH); delay(150); digitalWrite(ledPin, LOW); delay(150); } void loop() { sensorValue = analogRead(piezoPin); // Read the value from the sensor if (sensorValue >= threshold) { // If knock detected set brightness to max ledValue = 255; } analogWrite(ledPin, int(ledValue) ); // Write brightness value to LED ledValue = ledValue - 0.05; // Dim the LED slowly if (ledValue <= 0) { ledValue = 0;} // Make sure value does not go below zero }After you have uploaded your code, the LED will flash quickly twice to show you that the program has started. You can now knock the sensor or squeeze it between your fingers. Every time the Arduino detects a knock or squeeze, the LED will light up and then gently fade back down to off. The threshold value in the code was set for the piezo disc I used when building the project. You may need to set this to a higher or lower value depending on the type and size of the piezo you have used for your project. Lower is more sensitive and higher is less ALL ARDUINO TUTORIAL
