2021 Deep Anatomy of SQ-001 Soldering Iron
12/15/2020 at 08:19 • 1 commentAbout Soldering Iron
Hey guys,this is Candy, from Guangxi Crossing Aircraft Group.
I am an RC fan. Basically, as long as my friends around me organize competitive flying activities, I will participate. But in a competitive flying competition, all kinds of bombers are always unavoidable, and then they have to go back home for maintenance. An activitie died like this...
Until I bought a DC soldering iron-SQ-001 that can be used outdoors, it is mini, portable and supports 3-6s Lipo lithium battery power supply. Let me repair my drone anytime, anywhere.
Many friends will ask, there are so many mini soldering irons, why should I choose SQ-001 soldering iron? Below I will conduct a deep dissection of the SQ-001 mini soldering iron, so that I can know why I chose this soldering iron.
In the field of mini electric soldering iron, the function of SQ-001 electric soldering iron can be said to be very powerful. We will introduce its functions one by one in the article, but I want to express it to everyone in a way from the outside to the inside.
Deep Anatomy of SQ-001 Soldering Iron —— Appearance
The main colors of the SQ-001 soldering iron packaging box are blue and white, with a very soft color temperature. The transparent design of the front opening window makes people know what it looks like at a glance, so when I open the express box, I can calmly read the text description of the box. Then opened the box very violently, and omitted N characters here...
Open the box and take out the main things: SQ-001 controller, soldering iron tip, XT60 power cord, bakelite soldering iron stand, large and small manuals.As you can see from the picture, the SQ-001 soldering iron is mainly divided into two parts, the intelligent controller and the soldering iron tip.
The controller has two colors to choose from: Blue and Black.
There are 8 types of soldering iron tips: TS-B2, TS-BC2, TS-C4, TS-D24, TS-I, TS-K, TS-KU, TS-C1.Regarding the power cable, the XT60 power cord is shipped by default.
But for the power cable, SEQURE also provides XT30, T-Plug, DC5525 for additional purchase. Or leave a message to them when you buy: Please replace the XT60 power cable with XT30.
In this way, they will ship according to the content of your message.I chose the black K-head (knife type). This soldering iron tip is a multi-function soldering iron tip that uses a knife-shaped partial soldering, which can be vertical or pull soldering, which can meet most of my daily work. You can also choose according to your own habits and hobbies.
The smart controller looks like a pen, no wonder the soldering iron is called "soldering iron pen/soldering pen". The length of the intelligent controller is 97.22 mm (3.83 in) and the weight is 35 (g), which is very light and portable. This small controller contains internal components, 304 stainless steel nested ABS + PC housing and OLED screen.
On the top of the smart controller, there is a MicroUSB interface and a DC5525 interface. Among them, DC5525 is the power interface, which supports 12-24V power supply, so that my laptop adapter can also be used.The MicroUSB interface is used to connect to a computer via a data cable for firmware upgrade and program setting. Here I want to mention that SEQURE has two firmwares for SQ-001, one is 100-400℃ temperature adjustment, and the other supports 100-450℃ temperature adjustment.
Beside the display screen, there is a screw for the ground wire, the main purpose is to resist static electricity and prevent induced voltage. This design is very user-friendly. When using an electric soldering iron, you can connect a ground wire, which can achieve anti-static and induced voltage, and the safety will be greater.
There are two buttons A and B on the smart controller. These two buttons are used for all control operations...
Read more
