Programming a SAMD bootloader using JLink & Linux
03/13/2019 at 09:14 • 4 commentsI have a custom board using a SAMD21 microcontroller (as used in Arduino Zero and other dev boards).
After soldering, the chip is blank and a bootloader is useful to upload code via the USB connection.
I found an excellent (as always) tutorial by Adafruit using a JLink probe to upload their custom bootloader here : https://learn.adafruit.com/how-to-program-samd-bootloaders/overview
Unfortunately, directions are only provided for a Windows computer, using Atmel Studio.
Here is how to do it using the JLink command line software under Linux (and it should work with Mac as well).
To enable/disable the bootloader protection, I found very useful information here : https://roamingthings.de/posts/use-j-link-to-change-the-boot-loader-protection-of-a-sam-d21/
You should create two files with the info from the above post :
File SAMD_set_bootloader_protection_8k.mot :
S214804000FAC7E0D85DFCFFFFFFFFFFFFFFFFFFFF63 S9030000FC
File SAMD_clear_bootloader_protection.mot :
S214804000FFC7E0D85DFCFFFFFFFFFFFFFFFFFFFF5E S9030000FC
In the same directory, download the Adafruit bootloader from https://learn.adafruit.com/how-to-program-samd-bootloaders/setup
So here is the complete process to burn a bootloader to a blank SAMD21 chip :
- Go to the directory where you put the two files above and the bootloader binary
cd ATSAMD21_Bootloader
- Start JLinkExe
$ JLinkExe SEGGER J-Link Commander V6.32h (Compiled Jul 5 2018 18:15:02) DLL version V6.32h, compiled Jul 5 2018 18:14:58 Connecting to J-Link via USB...O.K. Firmware: J-Link Lite-Cortex-M V8 compiled Sep 15 2016 12:05:01 Hardware version: V8.00 S/N: 518006749 License(s): GDB VTref=3.313V Type "connect" to establish a target connection, '?' for help
- Connect to the microcontroller. You have to specify the device type, SWD interface and you can use the default interface speed.
J-Link>connect Please specify device / core. : ATSAMD21G18 Type '?' for selection dialog Device>atsamd21g18 Please specify target interface: J) JTAG (Default) S) SWD TIF>s Specify target interface speed [kHz]. : 4000 kHz Speed> Device "ATSAMD21G18" selected. Connecting to target via SWD InitTarget() Found SW-DP with ID 0x0BC11477 Scanning AP map to find all available APs AP[1]: Stopped AP scan as end of AP map has been reached AP[0]: AHB-AP (IDR: 0x04770031) Iterating through AP map to find AHB-AP to use AP[0]: Core found AP[0]: AHB-AP ROM base: 0x41003000 CPUID register: 0x410CC601. Implementer code: 0x41 (ARM) Found Cortex-M0 r0p1, Little endian. FPUnit: 4 code (BP) slots and 0 literal slots CoreSight components: ROMTbl[0] @ 41003000 ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C0 ROM Table ROMTbl[1] @ E00FF000 ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB ROMTbl[0][1]: 41006000, CID: B105900D, PID: 001BB932 MTB-M0+ Cortex-M0 identified.
- Clear bootloader protection fuse
J-Link>loadfile SAMD_clear_bootloader_protection.mot Downloading file [SAMD_clear_bootloader_protection.mot]... Comparing flash [100%] Done. Erasing flash [100%] Done. Programming flash [100%] Done. Verifying flash [100%] Done. J-Link: Flash download: Bank 1 @ 0x00804000: 1 range affected (16 bytes) J-Link: Flash download: Total time needed: 0.050s (Prepare: 0.037s, Compare: 0.002s, Erase: 0.000s, Program: 0.003s, Verify: 0.000s, Restore: 0.006s) O.K.
- Reset the target
J-Link>r Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
- Upload the bootloader (you may have to change the bin file name).
J-Link>loadbin bootloader-feather_m0-v2.0.0-adafruit.9.bin,0 Downloading file [bootloader-feather_m0-v2.0.0-adafruit.9.bin]... Comparing flash [100%] Done. ...
Read more
