SIA Register Set
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II 05/03/2017 at 15:310 Comments
The Serial Interface Adapter (SIA) core is coming along nicely, if a bit slowly.
I've just implemented the Wishbone slave port for it. It exposes 16 bytes to the programmer, with 16-bit wide registers. Here's the register map for the core (with byte offsets), taken from the Verilog sources as of this posting. Not everything is implemented yet; I still need to finish the transmitter section, for example. Also, SPI features of my XST core aren't exposed and will be removed if not optimized away by synthesis tools. (As you can imagine, this is all quite preliminary still.)
// +0	CONFIG (R/W)
//	...........11111	Specifies character frame length,
//				including start, stop, and parity bits.
//	........000.....	Undefined.
//	.......1........	Enable RXC edge sensitivity.
//	......1.........	Enable RXD edge sensitivity.
//	...111..........	TXC mode.
//		000		Hardwired 0.
//		001		Hardwired 1.
//		010		IEEE-1355 Strobe (*)
//		011		Undefined.
//		100		Idles low; TXD transitions on rising edge.
//		101		Idles high; TXD transitions on falling edge.
//		110		Idles low; TXD transitions on falling edge.(*)
//		111		Idles high; TXD transitions on rising edge.(*)
//		* - reserved for this purpose, but might not be implemented.
//	..1.............	RXC edge polarity
//		0		Idles low; sensitive on rising edge.
//		1		Idles high; sensitive on falling edge.
//	00..............	Undefined.
// +2	STATUS	(R/O)
//	...............1	RX FIFO *not* empty.
//	..............1.	RX FIFO is full.
//	.............1..	TX FIFO *is* empty.
//	............1...	TX FIFO is *not* full.
//	.00000000000....	Undefined.
//	1...............	One or more other bits set.
// +4	INTENA	(R/W)
//	000000000000....	Undefined.
// +6	RCVDAT (R/O)
// +6	SNDDAT (W/O)
// +8	UNUSED			Unused; hardwired 0.
// +10	UNUSED			Unused; hardwired 0.
// +12	BITRATL			Baud rate generator.
// +14	BITRATH
//	1111111111111111	Lower bits of divisor.
//	0000000000001111	Upper bits of divisor.
//				Bit rate = 100Mbps / (divisor + 1)
