SIA Progress: Transmitter and its FIFO Complete
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II 05/06/2017 at 07:080 Comments
So, after cleaning out the garage, I decided to sit down and work on the SIA core's transmitter logic. I didn't need to do much to make things work; I just re-used my XST (eXpermental Serial Transmitter; no relation to anything from Xilinx) core's transmitter logic, and re-jiggered it to meet SIA's requirements.
I am quite pleased that the SIA is nearly complete. I just need to write the top-level `sia.v` file that binds the receiver and transmitter components together, and I'll finally have a workable, and reusable, UART that plays nicely on Wishbone B.4 bus.
