Building some more prototypes
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 03/21/2016 at 19:380 Comments
Now it's getting time to move on with the software... for that reason I started building some out-door ready prototypes...
Left, the new ones. The thing on the right is my development prototypes with break-out "headers" to stalk the firmware :)
Btw.: Check out Sigrok this software really rocks!
Not yet fully ready but almost... I intended to use Keystone 54 clips for the 18650 batteries. They seem to be not totally easy to get here in Europe... so I've to live with the separate holders for now.
I'm not absolutely sure about the scales to use yet... one prototype will get the wooden one (see last log) and for the others I might retrofit some existing ones...
73
