Some sensors are coming...
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 03/11/2017 at 16:420 Comments
4 prototype pcbs are ready for the fields... it's time to unveil the sensor-pcbs :)
Actually I've finished these in early december... you can see them on the left down below...
One is equiped with a Si7021 (the very left on) and the other is a BME280. Both have I2C-USB bridges on the board to easily interface to the rest of the system.
In front you see to not yet completly populated HX711-to-USB board...but it actually already talks USB :)
