Initial Tests, Success!
A project log for Graphene & Diatom Desalination of Water
Using Diatoms and Graphene clean fresh water can be produced from sea water, or contaminated aquifer's.
mechanicusMECHANICUS 03/20/2016 at 06:060 Comments
The initial testing with Dr. Pepper was successful. The caramel color in soft drinks is difficult to remove as it is thoroughly dissolved and can not be filtered out.
When filtering through graphene however, only water can pass through the individual graphene sheets. This separates the dissolved solids from the water as is shown here in this video.
