Ok, so to kick this off I'm going to detail what I've got currently, what I need, and what I won't be able to get due to current monetary issues :/
Right now I have two of the four monitors I'll need for imaging surfaces, in the coming few days I'll be modifying them, removing their casings and stripping them down so they look nearly identical. After I retrieve another two, I'll repeat the process and begin working on basic framing, building a housing for the electronics and to hold the holographic projection area at a comfortable level. there are certain things I need to work out, like the retrieval of the acrylic/glass that would be the desired size.
So right now I need almost everything to kickstart this, though the frame is relatively easy and I'm sure I'll get the design for it up soon.
But for now here are some notes and doodles I made getting this design on paper.
