Machine evolution formed WinchBot
A project log for Self replicating CNC for 194 (or more) countries
Creating a design for a CNC that is easy to replicate and suitable for diverse drives.
Norbert HeinzNorbert Heinz 03/02/2017 at 10:210 Comments
As a long test run I used CNC v3.2.1 to carve parts from 5mm polycarbonate needed to build my WinchBot:
I was grinding a lot of solid plastics to dust with a 1.5mm two flutes miller:
The machine performed very well, but the filter system definitely needs a redesign. I will use a reservoir outsides the bowl, so I can remove chips even while the machine is running.
