Hardware Install
A project log for RGB LED Matrix Animation Library
RGB LED animation for Arduino supporting arbitrary matrix sizes
robbie-nicholsrobbie nichols 04/08/2016 at 00:470 Comments
The example installation is close enough to call it complete. The Controls and power supply are in place in a little box I made out of plywood. The lights are installed under the top bunk and the light diffuser is installed. That was a simple rectangle frame I made out of plywood with a sheet stretched over it and stapled upholstery style.
These are the things that I have left to do:
I made a few mistakes along the way:
Diffuser frame with sheet:
LEDs without the diffuser:
