Second batch of the board(final version)
A project log for Arduino compatible Machine Vision dev board
HICAT.Liver it's powerful cam platform which embed professional webcam solution and atmel mcu: 1.100% Arduino competiable2.ARM based Linux
josephJoseph 05/17/2016 at 14:510 Comments
1. adding ceramic antenna in order to reinforce the signal when external antenna is off.
2. fixed outside shape to have better identity and user friendly when adding breakout board.
3. adjust the screw hole so that the screw wont affect the nearby electronic.
4. fixed the silk print layout.
