Base Partially Assembled
A project log for Laser Cut Mini Mill
Mini Mill that can be cut using a 3020 laser engraver
wudagemWudagem 05/03/2014 at 13:320 Comments
I cut the parts for the base and the main table and glued them together, as well as reduced the end of the threaded rod to fit into the flexible coupler. The next steps are to cut the linear rods to length, make an anti-backlash nut, mount the first stepper and get some basic electronics going to drive it. Then I can test the quality of the movement on the base table and see if any design revisions need to be made.
