Successful dry run with our desktop CNC machine
A project log for Sienci Mill One: Simplifying Desktop CNC Milling
CNC desktop machines are expensive and complicated. This machine changes all that.
andy-leeAndy Lee 05/23/2016 at 03:010 Comments
May 22, 2016
I went out to laser cut the frame on Friday and put the machine together today to see how it looks and test it out. The machine is designed to have 1 inch thick material for the frame (either wood or HDPE) but I just wanted to make a quick frame mock up using 1/4 inch acrylic.
Check out our video of our dry run!
Next step is to put together the wiring and electronics box for the machine. We’re really close to milling some actual parts so make sure to stay tuned for more updates on that!
laser cut parts
machine assembled
