Quick Update: BOM & Components Ordered
A project log for SunLeaf
A solar powered wireless picopower sensor module with cloud Datalogging and control geared towards agriculture and environmental monitoring
avrAVR 05/25/2016 at 23:072 Comments
So today the BOM (bill of materials for the uninitiated) is posted. This is only the prototype BOM, so some components are left out, later those components will be published once building and testing is complete. The BOM is below:
SunLeaf BOM
DesignatorValuePackageQuantityDigikey #MFR #PriceComment
C310.01uFC06031490-8269-1-NDGRM1857U1A103JA44DMurata Electronics North America0.03580 @ 4000CAP CER 10000PF 10V U2J 0603
C4, C7, C10, C11, C12, C13, C14, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C330.1uFC0402211276-1506-1-NDCL05B104JP5NNNCSamsung Electro-Mechanics America, Inc.0.00758 @ 10,000CAP CER 0.1UF 10V X7R 0402
R11MR040211276-3433-1-NDRC1005F105CSSamsung Electro-Mechanics America, Inc.0.00137 @ 10000RES SMD 1M OHM 1% 1/16W 0402
R2, R3, R4, R5, R19, R20, R21, R22, R331kR040291276-3430-1-NDRC1005F102CSSamsung Electro-Mechanics America, Inc.0.00137 @ 10,000RES SMD 1K OHM 1% 1/16W 0402
C15, C161uFC040221276-1445-1-NDCL05A105KA5NQNCSamsung-Electro-Mechanics-America,-Inc.0.04830 @ 100001µF ±10% 25V X5R Ceramic Capacitor -55°C ~ 85°C Surface Mount, MLCC 0402 (1005 Metric) 0.039" L x 0.020" W (1.00mm x 0.50mm)
R7, R82kR080521276-5287-1-NDRC2012F202CSSamsung-Electro-Mechanics-America,-Inc.0.00266 @ 5000RES SMD 2K OHM 1% 1/8W 0805
C324.7uFC040211276-1481-1-NDCL05A475KQ5NRNCSamsung Electro-Mechanics America0.08 @ 10000CAP CER 4.7UF 6.3V X5R 0402
R11, R12, R13, R14, R15, R16, R17, R18, R27, R284k7R0402101276-3466-1-NDRC1005F472CSSamsung Electro-Mechanics America, Inc.0.001374.7k Ohm ±1% 0.063W, 1/16W Surface Mount Resistor Thick Film ±100ppm/°C 0402 (1005 Metric)
X28MHZABM3B8.000MHZB2T1535-9720-1-NDABM3B8.000MHZB2TAbracon LLC0.30450 @ 50008MHz ±20ppm Crystal 18pF 200 Ohm 20° C ~ 70°C Surface Mount 4SMD, No Lead (DFN, LCC)
C5, C69pFC040221276-1616-1-NDCL05C090CB5NNNCSamsung Electro-Mechanics America, Inc.0.00462 @ 10,000CAP CER 9PF 50V NP0 0402
R6, R2610KR040221276-3431-1-NDRC1005F103CSSamsung Electro-Mechanics America, Inc.0.00137 @ 10000RES SMD 10K OHM 1% 1/16W 0402
C2, C318pFC040221276-1647-1-NDCL05C180GB5NCNCSamsung Electro-Mechanics America, Inc.0.00756 @ 10,000CAP CER 18PF 50V NP0 0402
R23, R2422rR04022A102720TR-NDCPF0402B22RE1TE Connectivity AMP Connectors0.10921 @ 1000RES SMD 22 OHM 0.1% 1/16W 0402
R2547KR040211276-4416-1-NDRC1005J473CSSamsung Electro-Mechanics America, Inc.0.00137 @ 10000RES SMD 47K OHM 1% 1/16W 0402
C147pFC040211276-1697-1-NDCL05C470FB5NNNCSamsung-Electro-Mechanics-America,-Inc.0.01335 @ 500047pF ±1% 50V C0G, NP0 Ceramic Capacitor -55°C ~ 125°C Surface Mount, MLCC 0402 (1005 Metric) 0.039" L x 0.020" W (1.00mm x 0.50mm)
U574HC40521568-1456-1-ND74HC4052D,653NXP-Semiconductors0.13695 @ 2500IC MUX/DEMUX DUAL 4X1 16SOIC
R9100KR04021Standin O603N/AStandin 0402
R29, R30, R31, R32200 ohmR040241276-3959-1-NDRC1005F201CSSamsung Electro-Mechanics America, Inc.0.00203 @ 10KRES SMD 200 OHM 1% 1/16W 0402
RN1, RN2, RN3, RN4200 ohmEXB-N8V201JX - CAC-50P200X100-8N4Y10201CT-NDEXB-N8V201JXPanasonic Electronic Components0.00842 @10000RES ARRAY 4 RES 200 OHM 0804
C1710uFC060311276-1038-1-NDCL10A106KQ8NNNCSamsung Electro-Mechanics America, Inc.$0.05145CAP CER 10UF 6.3V X5R 0603
J2FTSH-105-XX-X-DV1609-3695-1-ND20021121-00010C4LFAmphenol FCI0.32 @ 1500020021121-00010C4LF ARM COrtex JTAG
P261300211121613002111211732-5315-ND61300211121Wurth-Electronics-Inc0.08910 @ 5002 Positions Header, Unshrouded Connector 0.100" (2.54mm) Through Hole Gold
P361300311121613003111211732-5316-ND61300311121Wurth-Electronics-Inc0.10396 @ 5003 Positions Header, Unshrouded Connector 0.100" (2.54mm) Through Hole Gold
P161300621121613006211211732-5295-ND61300621121Wurth-Electronics-Inc0.38610 @ 5006 Positions Header, Unshrouded Connector 0.100" (2.54mm) Through Hole Gold
X1ABS07-32.768KHZ-9-TABS07-32.768KHZ-9-T1535-9544-1-NDABS07-32.768KHZ-9-TAbracon LLC0.18000 @ 3K32.768kHz ±20ppm Crystal 9pF 70 kOhm -40°C ~ 85°C Surface Mount 2-SMD
J13, J14, J15, J16B3B-PH-K-S(LF)(SN)B3B-PH-K-S(LF)(SN)4455-1705-NDB3B-PH-K-S(LF)(SN)JST$0.19CONN HEADER PH TOP 3POS 2MM
SW1, SW2B3U-1000PB3U-1000P2SW1020CT-NDB3U-1000POMRON0.55 @7000SWITCH TACTILE SPST-NO 0.05A 12V
J5, J6, J7, J8, J9, J10, J11, J12B4B-PH-K-S(LF)(SN)B4B-PH-K-S(LF)(SN)8455-1706-ND B4B-PH-K-S(LF)(SN)JST$0.24CONN HEADER PH TOP 4POS 2MM
D1BAT20JFILM - DIOM1712X11NBAT20JFILM - DIOM1712X11N1497-3381-1-NDBAT20JFILMST Microelectronics$0.44DIODE SCHOTTKY 23V 1A SOD323
D4, D5BAV70SBAV70S2568-5004-1-NDBAV70S,115NXP0.055 @ 15KDIODE ARRAY GP 100V 250MA 6TSSOP
FB1BLM15HG601SN1DBLM15HG601SN1D1490-3998-1-NDBLM15HG601SN1DMurata Electronics North America0.05090 @ 10000FERRITE BEAD 600 OHM 0402 1LN
U2bq24210 - QFN50P300X200X80-10Nbq24210 - QFN50P300X200X80-10N1296-28738-1-NDBQ24210DQCTTexas Instruments1.46250 @ 1250IC BATT CHARGER LI-ION 10WSON (USB & SOLAR Input)
Q1DMG2307L-7 - SOT92P240X102-3NDMG2307L-7 - SOT92P240X102-3N1DMG2307L-7DICT-NDDMG2307L-7Diodes-Incorporated0.08100 @ 3000MOSFET P-CH 30V 2.5A SOT-23
J1DX4R005J91R5100DX4R005J91R51001WM17143CT-ND4758900010.50808 @ 500Micro USB Jack B
DA11ESDA6V1BC6ESDA6V1BC61497-6635-1-NDESDA6V1BC6STMicroelectronic0.126 @ 15KTVS DIODE 5VWM SOT23-6
IC1ESP8266 ESP-02ESP8266 ESP-021Ebay includes antennaESP-02ESP8266 ESP-02 WIFi SoC Module
D2LED GreenLED0603_GREEN1160-1446-1-NDLTST-C191KGKTLite-On Inc.0.03760 @ 5000LED GREEN CLEAR 0603 SMD
D3LED OrangeLED0603_ORANGE1160-1445-1-NDLTST-C191KFKTLite-On Inc.0.03760 @ 5000LED ORANGE CLEAR 0603 SMD
FB2MI0603K300R-10MI0603K300R-101240-2373-1-NDMI0603K300R-10Laird-Signal Integrity Products0.01920 @ 4000FERRITE BEAD 30 OHM 0603 1LN
U4PCA9518DBQRPCA9518DBQR1296-22764-1-NDPCA9518DBQRTexas Instruments0.95062 @ 1000IC EXPANDABLE 5CH I2C HUB 20QSOP
DA1, DA2, DA3, DA4, DA5, DA6, DA7, DA8, DA9, DA10SOT95P230X110-3NSOT95P230X110-3N10568-4041-1-NDPESD3V3L2BT,215NXP Semiconductors0.14067 @ 15,000TVS DIODE 3.3VWM 26VC SOT23
R10487R040211276-3991-1-NDRC1005F4870CSSamsung Electro-Mechanics America, Inc.0.00203 @ 10KRES SMD 487 OHM 1% 1/16W 0402
J3S2B-PH-K-S(LF)(SN)S2B-PH-K-S(LF)(SN)1455-1719-NDS2B-PH-K-S(LF)(SN)JST$0.17CONN HEADER PH SIDE 2POS 2MM
J4S3B-PH-K-S(LF)(SN)S3B-PH-K-S(LF)(SN)1455-1720-NDS3B-PH-K-S(LF)(SN)JST$0.17CONN HEADER PH SIDE 2POS 2MM
U1STM32F446RET6 - TSQFP50P1200X1200X160-64NSTM32F446RET6 - TSQFP50P1200X1200X160-64N1497-15376-NDSTM32F446RET6ST Microelectronics
U3TLV1117LV - SOT230P700X180-4NTLV1117LV - SOT230P700X180-4N1296-28778-1-NDTLV1117LV33DCYRTexs Instruments0.27 @ 1000IC REG LDO 3.3V 1A SOT223
TP1, TP2Alligator-TPAlligator-TP2Adam Vadala-RothSocket
TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10, TP11, TP12, TP13, TP14TP-2TP-212Socket
Also I have gotten notice from @oshpark that the panel the SunLeaf boards were on got sent to the fab yesterday, PCBs will be in the mail in about 10 days, I estimate a similar arrival for the components from digikey. When all arrives I will be hand assembling the first three SunLeaf modules under a microscope. Last thing, the BOM is available in open document format in the files section of the project page. Stay tuned for more soon!
Keegan Reilly wrote 06/07/2016 at 02:18 point
Nice work!  Just found your project, it is exactly the thing I was wishing I had this morning!  Can't wait to see the final version.  What is the unit cost given the current BOM?  What is your final unit cost goal?  Thanks!
AVR wrote 06/07/2016 at 04:40 point
Right not its costing us about 60 bucks per SunLeaf module, thats in a quantity of three,  in quantity it will be a lot cheaper. That cost is not accounting for assembly cost, I'm assembling the prototypes by hand for the sake of this project. We'll know more as we go forward, if there is a demand for these boards from people then I guess we'll have to figure out that when we get there. Thanks for your interest in my project and your appreciation.
