Parts arrival and assembly
A project log for Powerpole Distribution block
A power distribution block for Anderson powerpole connectors
Tyler Ward (Scorpia)Tyler Ward (Scorpia) 05/05/2016 at 16:040 Comments
All of the components as well as the PCB's and case acrylic have now arrived. meaning the board can now be assembled. Wasn't a hard board to assemble but does need a soldering iron with a large tip so that there is enough thermal mass to make the joint before heating up to much of the board.
Pile of comonents
The first test cut of the housing was successful, will add some laser engraving to the final version to mark maximum ratings and other important information. Ill put the cutter and cad files up when I have done this for anyone who wants to make one.
Unit in its housing
