First display tests are looking good
A project log for explorad
Work in progress: The explorad combines a microcontroller, a display, and star charts in a head-up display for astronomical telescopes.
christophChristoph 05/08/2014 at 23:240 Comments
Display is working after a major rewrite of old code and uses about 14% CPU to draw the telrad circles at 25 fps. I might get away with a lower update rate, but the remaining power should be enough to implement quite a lot.
