Initial software released here:
github.com/doobie42/pegasus3dprinter.git/
It requires a new BBB (don't try using the FSL3D provided one).
You'll need to enable the PRU and LCD4 in beaglebone black, then you can use the DTB and run the application; instructions are still in development.
