OpenSCAD design
A project log for Minimum Height Rostock Max Filament Spool Holder
...because it's too damn tall to begin with
benchoffBenchoff 03/29/2016 at 19:510 Comments
module slot()
  union(){
      hull(){
          translate([-10.1,0,-0.1])
            cylinder(h=5.2, d=5);
          translate([10.1,0,-0.1])
      hull(){
          translate([10.1,0,5])
            cylinder(h=5.1, d=18);
          translate([-10.1,0,5])
module base(){
    difference(){
        hull(){
            translate([96.8, 26, 0])
                cylinder(h=10, d=5);
            translate([-96.8, 26, 0])
            translate([96.8, -26, 0])
            translate([-96.8, -26, 0])
        translate([95,0,0])
            slot();
        translate([-95,0,0])
            slot();
        translate([65,5,-5])
        cylinder(d=20, h=15);
        translate([-65,5,-5])
module arm(){
    difference(){
        union(){
            hull(){
            translate([0,22,0])
                cylinder(d=10, h=20);
            translate([0,-22,0])
            translate([170,146,0])
            translate([170,170,0])
            hull(){
                translate([180,146,0])
                translate([180,160,0])
                translate([200,130,0])
    translate([167,115,0])
        cylinder(d=50,h=25);
    rotate([-43,90,0])
        translate([-10,5,-15])
            cylinder(d=10, h=270);
module complete(){
    difference(){
      union(){
       translate([75,-1,5])
        rotate([0,-90,0])
            arm();
        translate([-55,-1,5])
            rotate([0,-90,0])
                arm();
        base();
    translate([65,-10,-10])
        rotate([-43,0,0])
        cylinder(d=18, h=35);
    translate([-65,-10,-10])
        rotate([-43,0,0])
complete();
Press F6, and you get this:
