First Dashboard Prototype
A project log for Pedaless - eBike innovation
Unique accessory for your bike
boskobosko 03/30/2016 at 14:510 Comments
Here is how the first prototype of the dashboard looks. In the picture you can see the Wireless module, OLED display and buttons. The squares from the top left of the OLED Display present the communication with the Motor an GPS. When they blink it mean that some data is received form GPS/Motor. Top right side of the display is where you can see battery status. In the middle of the screen with big numbers is the speed calculated from GPS. Bellow the speed is the travel distance (odometer), which is calculated from the GPS. Above the speed the power of throttle is presented. It goes from 0% to 100%, all depends on how analog/digital throttle is pressed.
See how all of that looks in the next video.
