32kHz oscillator working
A project log for xkcd.com/now clock in hardware
as I work with people all over the globe, I need a simple way to tell their local time without hanging lots of clocks on my wall
rawerawe 06/15/2014 at 21:300 Comments
32768Hz oscilator works now 1-1.5V. I thought about further optimizing the design to only use one hex inverter IC and found the "wenzel clock divider http://www.techlib.com/files/dividers.pdf which I really like, but I was unable to get it running reliably for varying supply voltage to provide constant divider factor of two...
The oscillator consumes 2-3 uA (2uA for 1V, 3uA for 1.5V). This is relatively easy to measure with a multimeter in DC mode, as the current is nearly constant (the decoupling cap makes it possible).
How much does the clock run shorter with the added circuitcy on one battery?
There is a table of AA battery characteristics: http://www.powerstream.com/AA-tests.htm
As a rough estimation: 1Ah / 3uA = ~38 Years.
To measure the power consumption of a clock, just with a multimeter, is not as easy, because it draws pulse currents into an inductive load (which depends on the position of the constant magnet??). Calculation would base on a lot of assumption, measurement setup would involve a shunt resistor and scope, which I don't have handy right now - too much effort for an estimation.
As I have to replace my clocks batteries approx. every ~3 years (26280 hrs) , this means an avg. current of 38uA. With 41uA, run time would be 2,78 years instead of 3,  = 7% / 80 days less.
Clock power consumption measurement to follow...
