Failure is always an option.
A project log for Low cost worm gear drive for 3D printer Z axis
A low cost worm gear drive that prevents a belt-lifted bed from dropping when motor power is cut.
mark-rehorstMark Rehorst • 04/08/2018 at 13:09•0 Comments
I wish I could say otherwise, but this project looks like a failure, at least for high accuracy positioning.  It's works great for torque multiplication and appears to have pretty good precision, but a 3D printer Z axis needs both precision and accuracy.
There's a problem visible in the video below: when the Z axis is moved in 1 mm intervals, every other step is right on and those in between are a little off.
UMMD 40:1 worm drive precision testing and belt stretch under load from Mark Rehorst on Vimeo.
 I managed to repair the extruder and ran a test print yesterday and got Z ribbing every 2 mm, most likely because of a problem with the worm gear which spins 1 revolution for every 2 mm of Z axis movement.
I don't think there's anything that can be done to fix this.  I'll be putting the Rino back into the machine today.
