Electronics Lab
A project log for EduCase Portable Classroom
A self contained classroom suite in a portable case for use anywhere in the world regardless of infrastructure
Eric WiiliamEric Wiiliam 10/03/2016 at 15:100 Comments
As you may have guessed, I really wanted the EduCase to make it easy to teach STEM topics and very much wanted to include a basic electronics/Arduino lab. The software/teaching tools side was easy. I added dozens of documents covering all areas of basic electronics and Arduino programming
To power electronics projects I knew we will need a power supply capable of full control like a lab unit would be. These little adjustable units are just what I needed:
There will always be situations where I wish I would have a different power supply, voltage or current rate so with this available- I should always have what I need in the field.
