Two possible designs
A project log for Camera Traps for Citizen Science
Camera Traps can empower local communities & schools to observe & learn about wildlife. We aim to create an affordable DIY solution for all.
Egle Marija RamanauskaiteEgle Marija Ramanauskaite 04/17/2016 at 10:330 Comments
Came up with two possible designs:
1) Raspberry Pi approach:
Pros:
+ can connect to any WebCam (or any additional tools if necessary) via USB
+ can be connected straight to a monitor for analysis later
+ would not consume too much battery power
+ can be programmed to stand by (save energy) when there is no action, and woken up again to take the picture
+ easier to reproduce and build yourself
+ can program anything on Linux
Cons:
- difficult to get Raspberry Pi Zero
- would take time to program on Linux
2) KeyChain Camera approach:
Pros:
+ cheap parts
+ easier to get the parts
+ there are also better KeyChains with PIR included etc. – but more expensive
+ easier to program
+ uses less battery life
Cons:
- would need to install a bigger battery
- requires soldering
- photo resolution not so great
