Step Two
A project log for DS1307 RTC Breakout Board
A breakout board with the DS1307 Real Time Clock and battery backup
MarkMark 05/04/2016 at 19:320 Comments
Finally received a shipment from China with some badly needed DuPont cables. That means i can can now hookup everything at once, finish the alarm clock software and publish the lot. I made a small breakout board with four switches to use as OK, Cancel, Up and Down buttons.
More details to follow...
