Erata
A project log for The Diode
I'll explain some simple diode functions using Snap Circuits.
steve-schulerSteve Schuler 04/20/2016 at 12:190 Comments
Found a footnote call out without an actual footnote. Initially I had intended to use the Ben Franklin bit as a footnote, but since I put the Ben Franklin bit in the body of the article, I removed the footnote call out.
