Upload Test
A project log for COCITO WEATHER STATION
IOT Weather Station with Air Quality monitoring
matteo-monselloMatteo Monsello 05/29/2016 at 20:120 Comments
Yesterday we run a 7 hour test to check if everything works fine with the main board. We were at the same point excited and disappointed about the results: the hardware works without problems (wich was the main goal), but the station wasn’t able to upload data 8 times for about 15 minutes each.
We are putting all our efforts to solve that problem.
We made 3 hypothesis:
If you want to look at the results here is the link to our Thingspeak channel: https://thingspeak.com/channels/116312
