(extreme) soldering Part One
A project log for 192:LED
Extreme tiny (0,68'‘ x 0,68’‘ or 17mm x 17mm) smart RGB LED display/matrix
alexAlex 05/25/2016 at 19:257 Comments
The bottom side is soldered. It was quite difficult to get the 0201 capacitors (the two next to the crystal) soldered correctly. The dimension of crystal is 2 x 1.6 mm.
Next Task is to solder the to side with its 64 RGB Leds. But I will not do that today. One side a day extreme soldering is enough. And then I hope it will also work.
aishamontrset wrote 05/28/2016 at 05:40 point
nowone   is    scairdy  cats
aishamontrset wrote 05/28/2016 at 05:39 point
i  dear   someone  ton  toghch  one!
zakqwy wrote 05/27/2016 at 13:53 point
whoa 0201s! Well done!!
oshpark wrote 05/27/2016 at 05:40 point
impressive!
Eric Hertz wrote 05/27/2016 at 07:10 point
seconded! Thems some tiny capacitors!
K.C. Lee wrote 05/27/2016 at 09:23 point
Good job on placing those caps.
Alex wrote 05/27/2016 at 13:36 point
Thanks
