Test on PrefBoard
A project log for OneWireKeypad adapter
A simple board to convert matrix keypad with 8 pins to use only one ADC pin and VCC-GND.
malhar-deshmukhMalhar Deshmukh 04/25/2016 at 04:080 Comments
I built the circuit on a prefboard. Works nicely. Keys in bottom row don't work. All print 'D' when pressed. Need to see what's wrong.
Still using old resistor values. Ill change resistors when order reaches me. Photos of build posted. Other side of board will be posted when it arrives on my OneDrive.
