Boards Ordered
A project log for Atari2600 Cartridge Reader
Extract game roms and play them on an emulator
koen-van-vlietKoen van Vliet 08/21/2018 at 10:520 Comments
To connect the STM32 to the cart edge connector I designed a small adapter board. It is designed to screw into the back of the connector housing. It contains some female headers. I placed a solder jumper to connect shield ground to the ground plane. It would be possible to place a small surface mount inductor here. I have ordered 10 of these PCBs, which contain 40 adapter boards in total.
Cartridge Reader Assembly
Cartridge reader assembly with the adapter PCB (green) attached to the connector housing.
Panelized PCB
A panel of 4 adapter PCBs
