A slight design change to the DH 4.2 Homemade spectrometer (build 4.0.1)
A project log for DAV 4 UV/VIS Spectrometer
Well, this is the next evolutionary step from when I first bought the Plab 2.5 spectrometer kit
david-h-haffner-srDavid H Haffner Sr 05/28/2016 at 18:110 Comments
I had to make some design changes because of some stability issues I was having, like mis-alignment of the cuvette holder relative to the front coupler that houses the entrance slit.
Now there is only 1 cm from the face plate to the lip of the coupler for the cuvette holder to fit over, this seemed to make a remarkable improvement on the line of sight alignment form cuvette through slit to cmos camera eye on the emission spectra.
I also gave her some feet!
