ESR METER
ESR (Equivalent Series Resistance) meter measures ESR of capacitors in circuit and displays on a 10 LED bar graph meter. www.HecKits.com
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
ESR (Equivalent Series Resistance) meter measures ESR from .1 ohm to about 30 ohm and displays result on a 10 LED bar graph meter. Uses 50 KHz to test capacitors in circuit to isolate faulty component. <a href="http://www.HecKits.com" target="_blank">www.HecKits.com</a>
