Learning KiCAD
A project log for Open LIDAR
This project is to build a motorized gimbal mount to convert a laser distance module into a 3d LIDAR.
caveradamcaver.adam 09/12/2016 at 01:050 Comments
So...it took me a bit longer to learn to use KiCAD than I had expected. But, I've entered the schematic now. And I've learned how to create PCB footprints. Hoping to get this circuit board on order tomorrow. But tonight I need to sleep so I can have energy to verify the schematic after work tomorrow. Measure twice, cut once.
[Image removed. See revision 1a PDF file in the files section for updated schematic].
