Limit switches and fitment of linear rail
A project log for KOSSEL XXL
I wanted to build a large printer capable of printing PLA or ABS to a high quality, speed is also of major importance. (Mini Kossel based)
aaron-dominic-richmondAaron Dominic Richmond 05/10/2016 at 12:070 Comments
Before fitting the linear rail i want to pass some wires up the middle of the vertical extrusions for my 3 endstops, I used the pillar drill to put some holes in the extrusions just above where the bottom corner brackets will come to.
The wires can then pass through the holes loop over the top and be connected to my limit switches.
The linear rail was then bolted to the verticals using some 8mm M3 cap screws and t-nuts.
