In the meantime ...
A project log for HumidIOTy
Humidity & Temperature automation system with data logging
arturo-aldaco-pereaArturo Aldaco Perea 06/27/2016 at 16:150 Comments
Well, right now i'm waiting for the parts to arrive, so in the meantime i would like to explain the reason this project was started and how controlling humidity helps us do our job.
I work at a branch of an LCD TV manufacturer company (i'm not sure if i can say what company), in this branch we do refurbishment of LCD Open Cell that didn't met customer specifications, such as polarize stains, foreign materials, vertical lines etc.
As you already know these are delicate electronics, specially when dealing with expensive 80" ~ 90" sizes (yikes).
For the repair process we have a clean room with controlled access, temperature & humidity, for these last two the control is manual, that means that someone has to be checking the temperature & humidity monitor and adjusting the devices accordingly to be within specified range.
We are human after all, we make mistakes, forget things and when we think we are really awesome we tend to do both at the same time.
The big issue this project is trying to solve is air particle control by having an automatic system instead of a manual one. These pesky particles can screw up things big time, polarize repairs are the ones affected the most, imagine applying a polarizer sheet to an 80" Open Cell, only to have a particle less than a mm in size screw up the whole process, throwing away a $300 polarizer sheet, making you start all over risking breaking the Open Cell ...
Other affected area is SOF repair (they are the Tabs you see at the top & sides of the Open Cell), the part of the SOF that's bonded to the LCD glass has tiny traces for wish we need a microscope, having a particle fall in this place can cause vertical lines to appear in the LCD or if the particle is big enough it can create irregular heat pattern when bonding, and this can cause the LCD to brake.
By controlling the humidity we can lower the amount of particles in the air, and avoid dispersing particles someone might have already with them.
