Design Dialogue 2 - Component iterations
A project log for Humidifeyes
Eye Moisture Retention and Rehabilitation Goggles: Cost effective assistive device for prevention and treatment of dry eye syndrome.
spandana.cheruvuspandana.cheruvu 08/30/2016 at 16:570 Comments
I have experimented with all shapes for the mist producing chamber. The piezo is the main component with diameter of 1.5cm. The height of the element is ~1mm.
I thought of two ideas for the chamber. The first is like a standard room humidifier design with a cylindrical spring loaded latch.
The second design in a strap on piezo cap on horizontally oriented wick container. The strap are press fit on the cylindrical surface.
Among the two pics first is horizontal orientation while the later is vertical.
