Implementing WiFi-Direct in Arduino library WiFi101
A project log for 1Sheeld in 0$
Save $ on bluetooth serializer and enjoy 1Sheeld for free on MKR1000 or any Arduino with WiFi Shield 101
asad-ziaAsad Zia 05/17/2016 at 11:173 Comments
Atmel website says that the chip WINC1500 supports WiFi-Direct. The WiFi101 software library that comes with Arduino IDE has no API that indicate WiFi-Direct support. The first step is to add WiFi-Direct functionality into WiFi101 library.
I forked the WiFi101 on github and soon discovered that the file WiFi.cpp is the best place to implement the additional APIs needed to connect to WiFi-Direct. I added the follwing APIs:
* Start Wifi as P2P device. P2P is also known as Wi-Fi Direct.
* param name: Set your device name which will be shown in the peer device.
* param channel: Wifi channel to use. Valid values are 0, 5 and 10.	*
uint8_t beginP2P(const char *name);
uint8_t beginP2P(const char *name, uint8_t channel);
This follows the same design pattern as the other APIs for configuring WiFi in station mode or Access Point mode.
There is already an infrastructure in place to handle callbacks. I reused the same logic and implemented the WiFi-Direct API. I added a new example to demonstrate how to connect to WiFi-Direct, it is:
#include <WiFi101.h>
char name[] = "wifi101-p2p"; // P2P device name
void setup() {
  // attempt to connect to Wifi-Direct:
  if ( WiFi.beginP2P(name) != WL_CONNECTED) {
    // don't continue:
    while (true);
  // you're connected now, so print out the data:
  printCurrentNet();
  printWifiData();
void loop() {
  // communicate normally
When I coded everything and ran it, it did not connect. On investigation it turned out that I cannot use channel values between 1 to 12 as is the case for Access Point mode. The only allowed channel values are 0, 5 and 10. On using the correct channels it worked like a charm. Please see the connection dialog from Android below:
You can find the updated library and working example at github https://github.com/asadziach/WiFi101
flipkart010 wrote 01/02/2017 at 12:38 point
How to configure the esp to wifi direct
david wrote 11/28/2016 at 03:52 point
great!! thanks now.. how do i receive data from peer and turn on a LED?
thank you!
flipkart010 wrote 01/02/2017 at 12:40 point
did anyone reply
