a case for the future
A project log for Buzzer System for Trivia Events
A low cost wireless buzzer system to aide with trivia events.
k-gilbertK Gilbert 05/29/2016 at 21:502 Comments
Today design turned poligonal with thoughts of case working floating in my head first concern was power, looking through the usual retailers i found that battery trays would increase the size and price beyond what i was comfortable with, I then looked at just the metal clips that hold batteries in place, they too are too expensive. Early this morning i was thinking and i saw a roll of very stiff wire on my desk and thought i could use that to make springs. so i quickly drafted up a case to hold a design and printed it off to test. You can see below the rigid 0.8 mm wire can fit into the groove and can be bent in usual battery clip shapes.
Here it is in person.
So from here I morphed out this design to fit in the circuit and buttons and lights. Since i'd like to have the circuit boards in my hands first before putting too much work into this, these are more of mock ups than revision ones.
K Gilbert wrote 05/29/2016 at 22:08 point
You are correct 0.30 usd is not too much,  but I could integrate my own design into the case for about 5 cents per unit. (note: i am clearly and intentionally valuing my time at zero)
It was all a choice here because I knew I went over budget on the circuit board., by switching from hand wiring to pcb. Thanks for reading.
