How Difficult Is This To Make? How Long Will It Take?
A project log for Affordable Reflectance Transformation Imaging Dome
A simple and inexpensive way to image and analyze subtle surface details on objects.
leszek-pawlowiczLeszek Pawlowicz 07/21/2016 at 02:510 Comments
I've had a few emails asking about how difficult this project will be to make, and how long it will take. Not exactly sure how to answer the first question, as it depends on your level of experience and willingness to learn. Having said that, if you know or can pick up simple soldering, and know how to use tools, there's nothing that you should find particularly challenging. Hopefully that's especially true because, for better or for worse, I'm trying to document every single step as thoroughly as I can.
As far as time, I think that if I were pushed, and had all the parts, I could probably put together a system in a long weekend plus a few extra weeknights (given the benefit of experience plus now having a set of written instructions). However, if you can grab a bunch of friends to help, much of the project could be broken down into subsections that people can work on independently of others (and even some of these can be broken into concurrent processes):
1. Dome prep, marking and painting
2. MOSFET driver shield assembly
3. LED driver board assembly
4. Enclosure preparation
5. Individual LED wiring
6. LED Matrix / Dome wiring
7. Controller/enclosure assembly/wiring
8. Stand construction
With multiple assemblers at work, this can easily be a one-weekend project. Beer is a useful bribe.
As of today, I've got steps 1 and 2 fully documented in the instructions section. My hope is to have all the instructions up within a month or so.
