Newer controller board, with added features.
A project log for 3D Printed PCB mill
3D Printed components and other hardware to make a PCB routing machine, which inherently can do other things.
dteelDTeel 07/11/2016 at 06:080 Comments
I made a lot of modifications to my controller circuit board. I reduced the foot print and also added in a disable/enable line for the stepper drivers to save energy when its idle.
With that, I included 2 new commands into the controller software, disable steppers, and enable steppers, updated code is uploaded.
Below is a modified screen shot of the board. I just took a screen shot and filled in the areas with paint to make sure everything made sense before I milled it.
